Haymaker101
Hi eveeryone, been following forum for awhile, but first time posting. I have a 1976ish Internatioal 175c with the DT 466 engine. The machine has always been great until recently.
The push button starter was acting up this spring and would sometimes have no response when pressed, or it would click, or start machine. I only use the machine as needed on farm and it did not make it a priority to fix.
Now I cannot get the machine to turn over at all. I replaced the start button and now the machine constantly clicks. Now it only clicks, never starts. Both batteries tested good, it's a 24 volt system.
The last time the machine started, the starter got stuck and was making the humming noise after I shut it off and had to use the master battery kill to make it stop. Haven't been able to start since Friday. So, does this sound like a failed starter to you guys? Selanoid? I have check my ground best possible and don't see any bad connectios.
A
Any suggestions? The starter looks nearly impossible to unbolt, no room. Anyone have any experience? Is this system a positive ground by chance?
Thanks in advance, sorry for the long post
A
