I need to make it easier to climb in the grader since my legs are quite weak following a stem cell transplant. I got an idea from looking at some farm tractor steps. The steps come out at an angle so they're easier to climb than steps that go straight up. Then they have a hinge so the bottom half can fold up on the top half. They just use a rope to pull the bottom half up. I suppose a round bar could also be used to help push the bottom half down when coming out of the grader. I'd add more steps so they are closer together and easier to climb. I think some 2" channel would be sufficient for the sides. Not sure yet if if I'd have wider steps or just use rebar for the steps. I was thinking with rebar I could still use the steps when folded up if the blade was in the way. Rebar would give some grip. I'd have to watch carefully so I didn't hit them with the blade but when folded up wouldn't be any lower than the original steps.
