lgammon
ok we have a first generation 943 cat loader. it has served us well for a long time but is is haveing some problems that i would like to ask you guys about, hopfully some one here has already been here. when you get on the machine in the morning and start running it is fine but when you shut down the machine or even idle it down, when you go to idle it back up and run it one track sticks and it strains and then kind of jumps and starts working. while you are working after this the same track will seem to loose power and not want to move. now this is a problem that comes and goes some times you can go all day with out a problem but some days it does it almost out of the gate. it makes it really hard to go in a straight line you have to keep feathering the foot lever all day to keep it tracking stright. it kind of scares dad because no one we know has had this problem and the hydrstats are so expencive to repair. does any one know anything about these machines and this type of problem? i really want to keep this machine i like the size and cat no longer makes this size machine. it is just so handy around small lots.
thanks for all you advice in advance
