I SAW IT
Hi yall'
I'm Leroy - new here - first post..
Though I suspect I'll be around a bit as I have many upcoming Earth moving Ideas, that I'd like to build, and to save myself much money and trouble. I'd like to pick yall's brains before blundering into making any mistakes.
First let me begin with a bit on my background, novice engineer, plenty of small machine building, did professional body and paint work 10y, now do HVAC and electrical self employed 3y, going alright. But I want to do side business doing Earth work and Tree service, my buddy makes sh** tonne more $$ than me and works outside - I want some of that action as it's almost spring time and the economy here is growing for construction.
Also I bought a small parcel of raw land that i've been clearing out and shaping up, so these equipments I need to build to do my own work, and then to have to do side work for others, maybe advertise and get some jobs. My plans are modest, I cannot afford to buy a dump truck, dozer, excavator, bucket truck or anything much really, go I'm going to build my own facsimile of real equipment and paint it nice, maybe fake stickers - who knows.
My goal is 10% build costs of the real deal, with plenty adequate functionality for part time use. (see 'poor' not 'cheap') Also have a connection at a salvage yard for buckets, hydraulic misc, cylinders ect. but that stuff i'll tap for when I build a little excavator.
blah blah - hope I don't get TLR
cuts to the chase
Firstly, I am needing to build a dump bed - to fill dirt 18" over a few acres to fill in low spots on my land that flood in the spring, designing and building a dump bed to fit in my pickup truck / 85' F250 IDI DIESEL 4X4 4SP .
And I don't know anything about hydraulics, so I need you're help.
I picked up a 12v hydraulic pump for a cool 60 bucks. It squirts when a jumper cable is applied, the PO had it on a 14' flat bed E-series van and said it works good.
Does anyone recognize what type of pump this is? the cap is printed MTS, but the label has fallen off. I'd like to know so I can download the illustrated parts list, for understanding and repair parts if they become necessary.
The bed is going to be built of 4x10 ft, 1+1/8 plywood .. 4x4's, 2x4's ect .. and will be a slide in/ out deal when in use.
I thought about converting my truck bed itself, as i'm sure it would be same cost and effort, but my truck is nice. It does work exclusively, but doesn't 'look' like a work truck. and whenever I load up gravels, dirt, coal, stone ect .. they fellers want to use the biggest FEL they seem to have and dump 1/4 of the load onto the tailgate and bed rails. this wood insert dump bed will taper out and up and hang out the back. the stock tailgate will be pulled off when in use.
okay, so I have a pump, now for the cylinder side of the equation. I have a 3 tonne hydraulic jack that used to work good, a couple of months ago I messed up the pump handle part but the scissor mechanics and the cylinder are good. just the handle pump is broken. it'd lift my whole truck, so it's got to be able to lift a few tonnes of material.
so I would like to hook up this 12v pump to the hydraulic jack to go between the bed stock and the dump bed. There are several ports and screws on the auto jack, does anyone know what to do to plumb this to the pump?
Also, I understand I'll need some pressure relief valve yes? is it possible to run without one? where is said valve installed in the oil circuit? cheap vendor and pop pressure?
do i have to have a spool valve? this thing is just going up, then down.
can I just power it up off a solenoid for dump and release power to let the weight of the bed lower it back down?
can the 12v hydraulic pump go in reverse to lower the bed or at least start it in motion from a 1 sec power up.
should I just buy a 6 block bi-directional spool valve and relief valve and quit trying to pinch pennies? Is there safe redneck ways of doing this by cheapest means necessary, please speak up. I'm going for lowest cost that'll do the job.
i have to dump this dirt first, next project will be to build a little clevis mounted dozer blade with a 3x16"x6' oak slab blade on the front to push these piles around.. kinda like a cheap snow plow. plan on using these same hydraulic system for the actuators and cylinders and whatever gonna be needed for that .. anyway, getting a little ahead of myself .. any tips/ tricks from the pro's is greatly appreciated ..
thanks ! Leroy Sr.
Pics>
cuts to the chase
thanks ! Leroy Sr.
Pics>
