troyharnish
I want to change the hydraulic fluid and filter on my 2002 Case 580 M turbo, Just wondering if I could field a couple questions before I do it. I have enough mechanical know-how to change fluids and such, not much more, but I do like to change my own fluids to make sure they are done at the proper intervals.
* How tightly should the new hydraulic filter be screwed on? Similar to a regular oil filter (i.e.- hand snug then another quarter turn)?
* Can I use a regular filter wrench to change the hydraulic filter?
* In order to drain the hydraulic fluid from the tank, it looks like the plug has a large hex in it, what do I need to take the plug out?
Any guidance is appreciated.
