ANGUS BEEF
Hi, im looking for some help advice on my 580b. I believe its a 1975 Diesel model based on the serial number. Ive owned it about 20 years and its served me well. Ive had atleast half the cylinders rebuilt over the years. I should add that i havent seen any other 580bs in my area that have a 3 point in the rear with a box blade. Looks factory to me. Every 580b i have ever seen has a backhoe on it. Mine does not. Anyway, when i first got the tractor i could pick up about a 800lb ballast barrel with the 3 point no problem. It may settle some every 10 minutes but worked well. Well....20 yrs later it picks up the box blade but if i work the tractor hard for 15 to twenty minutes it barely wants to pick the box blade up. Does a little better picking up if i cheat it by pulling first to levers in that 4 lever control bank. Any ideas whats causing that? Does the whole bank need to have new O rings installed? I can see that oil weeps out of the top of the main lift lever. Im assuming as the oil heats up and gets thinner its bypassing somewhere? Im just mechanically inclined enough to be dangerous...haha so i dont know if i could tackle a job of this caliber. The other issue im having is that last summer i lost the ability of having down pressure regarding the front end loader. Meaning i cant pick the tractor off the ground by extending the curl cylinders. Also the bucket will not stay in position if im trying to grade or scoop imto a pile. It just floats on top of the ground. My curl up, like curling a round bale for my cattle works but it weeps down very quickly. Main lift has good power with no issues. Is this most like a curl cylinder issue or loader control valve? Lastly, i was finally able to get the hydraulic oil canister off. This appears to be an inline filter that is on the right side of tractor just forward of the loader joystick. I have never changed it. I admit im terrible with maintenance. It is a paper element and when i removed it it had gobs of what looked like torn up paper stuck to element. The element was not wrecked that i could tell so i dont know where that stuff came from. I cant find the filter number for that specific in line hydraulic filter. Could someone let me know what the part number is? I will be changing out the filter in the pump housing again. I had a reman pump put in it about 10 years ago and last changed that filter about 3 yrs ago. Sorry for the novel but looking for that fikter number and any advice on my hydraulic issues. I would assume it could get very expensive if i have to buy a new rear control valve for three point. Tractor just keeps running and i love the box blade as i have lots of gravel roads on my property. Wanna keep the 580b going as long as i can. Injection pump is starting to leak bad to so i just dont know how much i want to stick in the tractor but when i price anything newer and cant justify spending that king of money either. Thank you for reading my novel.
