farmerdavy
New to the forum-Thanks!
I'm in the process of repacking the hydraulic cylinders on my case 580d super. On the loader lift cylinder, I had to use a block of wood and a hand sledgehammer to slide the gland nut off the rod. It came off a fraction of an inch at a time. I was hoping that perhaps a seal was pinched or folded and new seals would fix it. No such luck! It's even harder sliding the gland nut with new seals back on the rod than it was. I noticed the inside of the gland nut, under the seals looks corroded and rougher than I would expect. Wondering if the corrosion has swelled the inside making the seals too tight. Any ideas are appreciated!
