Hi all
I recently put new seals in the dipper arm cylinder of my excavator.
Today was the first day I ran it properly since resealing.
There is a small weap of oil coming from between the gland nut and cylinder barrel.
I guess the oil is bypassing the o ring seal on the gland nut.
I used a genuine seal kit and made sure to use plenty of lube when reassembling the cylinder and also followed the workshop manual.
It is a threaded gland nut that is on the cylinder, not a cap with a ring of bolts.
If I was to unscrew the nut halfway, and apply thread tape or compound, and tighten the nut again, would you think it would seal it up?
Thanks
Thanks
