The master leveling cylinder for the platform located at the base of the boom? It's been a while since I've worked on one of those machines so I can't recall the configuration, but I'm thinking you should be able to remove the master cylinder with the boom fully up. Boom up all the way then tip the platform fully down using the ground control station. Once that's done, shut down engine, then power up the ignition at ground control station but don't start engine. Click the rocker switch for platform level in both directions, this should purge any remaining pressure on the lines connected to the leveling cylinder so you can disconnect them without taking a hydraulic bath
