I bought a TL26 last week, it's super clean, runs great, and everything is tight except for the attachment/bucket pins, they have some slop and need to be replaced.
I was able to find the bushings and seals, but the pins are listed as a backorder item. There has to be aftermarket options available though provided they are sized correctly.
Do I have to order the bushings and then measure the ID of them before looking for pins? They aren't anything too fancy, grease fitting on one end and a bolt through hole on the other.
I suppose alternatively couldn't I just get an OD measurement of the old bushings, and order matched parts, even if the pin size differs a bit from OEM?
