If you position the machine on uneven ground and it wants to rock, back up a little,scoop a little dirt and throw under the front of the tracks, and track up on the small piles. You have to gauge how much you need and which side deeds a little more. Let it rock a time or two and see where it's moving most.
They can be difficult to handle if their rocking back and forth. You get to bouncing around in the cab and pretty soon the machine is pulling the handles for you.
Renting a mini is a good idea, but don't be too discouraged if it doesn't go that well. I've always thought they are al little harder to handle than a full size machine, because they are so quick and they pull themselves around and over so much easier.
If your tracks are bad or out of tension keep them running on even ground as much as possible. If one gets out from under the machine you can hear and feel it. Pick that side of the machine up with the bucket and it will go back. If the track aren't in good shape, you have to be more careful about how you approach certain jobs.
I was too black and white when I said a track should never be run off an excavator. If you are running around with loose wore out ropes on it you will probably loose one once in a while.
