How to make easy effective site signs?
PhilDirt
Lancaster PA
I need to make signs to direct drivers at a fill site. I want something better than a spray can and a piece of used plywood, but don't need professional street signs made. What have you used for this? Are there good large stencils available? Cheap plastic letters to nail or staple to a board? This is going on for several years, the signs need to be durable or need to be cheap and easy enough that it doesn't matter that they need to be replaced often. The nature of a fill site requires frequent changes, arrows moved, etc. so I'd like to be able to make them up onsite as needed. Google and Ebay haven't offered up much.
Ideas anyone?
wornout wrench
canada
Find this stuff
http://www.coroplast.com/
Get the color you want, cut to the size you want, attach to what ever you want
Big felt pen, 1" tip or better, or go to your local office supply store, they should have the stick on letters.
The part I like about this stuff is you can have different colors to signify different applications
I've never made signs like that, but if I had to...
Use BC or better plywood cut to whatever size you want. Prime and paint all six sides ahead of time. Use a pencil and yardstick to layout you lettering and a small brush to paint it in. A big step up from a spray can in looks and durability.
The corrugated plastic and metal wire signs like the real estate agents use are pretty cheap and very easy to place. You might want to check a sign company locally who makes them.
