Hello all i have an idea and am hoping someone else has struck this before.
At the moment I'm building lease pads 4 gas rigs, it's a simple process.
Once u get the pegs sorted and strip just shoot a few levels create an rl set up your laser gear and cut and fill.
Ime using the slot method 2 cut and fill and leaving the slot rills on the fill once u get close to wear u need to b u split the pad into 3 even sections the middel is flat level and the edges have a 1 percent fall.
Now instead of cleaning up the rills and then changing the levels keeping in mind the middle will have to b lifted to allow for the fall on the edges if I can Work out how to judge the amount of dirt in the rills in theory I can use that dirt to put my falls on and elevate the middle.
Does anybody know how I can calculate this keeping in mind I can't go outside the pegs but I can change the level to make it work if I get it right my original rl should end up the half way point on the edge,and have no dirt left over.
A little help please there must b a way to it with math I just haven't learned it yet.
