amanda11270
I have an Altec AT series bucket truck, and some of the smaller hydraulic hoses are bubbled and need replaced. Most I can do easily as they all go to minor functions of the machine. However four of them are on the bucket leveling system. It appears to have the two hoses coming from the electric pump or return valving in the tower of the boom assy. They go to what looks like a manual valve assy on the top of the tower, where the hoses split between two that go to the power tilt function bucket, then to the sealed system auto leveling cylinder. My question is, are the things that look like manual valves that can be opened or closed with wrenches what I would use to bleed the air out after I change the hoses on the leveling cylinder lines (assuming its not going to bleed itself). Im sure the power tilt for the bucket will bleed itself, but the leveling I think I have to bleed my self. If you are not familiar with bucket trucks, its a small cylinder at the base of the boom, that has lines going up the boom that when the boom lifts, this small cylinders extends and levels the bucket using another cylinder at the end of the boom where the bucket is. But also this bucket can be power tilted as well. When I replace these leveling lines I think its gonna be all out of adjustment and would like to know where it is bled to adjust this.
I work as a refrigeration tech, electrician, plumber, but this is my first hoorah into hydraulics, I usually have a good idea how things work, just in the case I need a little information before proceeding, im not really messing with any of the heavy boom lift, or boom extension hoses, those are all larger sized and still in great shape. Just all these smaller 1/4 sized hoses have bubbles in them, and I would like to be proactive before they fail and start actually leaking fluid.
