How to be sure turbo is working correctly?
Discussion in 'Tractor/Loader/Backhoes' started by csthompson12, Oct 17, 2020 at 2:15 PM.
  1. csthompson12
    csthompson12 Well-Known Member
    Nov 25, 2010
    90
    usa
    I have a 2006 JCB with a 1000 series Perkins turbo diesel. I can’t seem to detect any turbo whistle or whine under load like I can with other machines. I did take the boot off the intake side and and spin it by hand and it does seem to spin fairly easily. I’m just used to hearing in other machines - trucks, grader, other backhoe etc..
    skata likes this.
  2. Delmer
    Delmer Senior Member
    Jan 4, 2013
    6,308
    You can measure the boost pressure at full load. Not sure if you'll find a spec for that model, but it will show it's working if you get even 5 PSI. Engine needs fuel and load to produce boost though, just because it's low, doesn't mean the turbo is bad.
  3. mitch504
    mitch504 Senior Member
    Feb 27, 2010
    5,048
    Andrews SC
    If your turbo isn't working, you'll get black smoke out the exhaust
    Tinkerer and oarwhat like this.
  4. skata
    skata Senior Member
    May 10, 2007
    872
    midwest
    I had a jcb telehandler with the same engine and had the same thought once. Even checked the turbo like you did. Came to conclusion it was normal. Only other thing you could check is the wastegate on the turbo. If it's stuck open, then it won't build boost.
  5. stinky64
    stinky64 Well-Known Member
    Feb 25, 2017
    59
    big truck wrench/fixer of things
    java center ny
    If its got an air cooler in between the turbo and intake,may be leak in cooler,hole in boot,loose or broken clamp....try spray bottle w/soapy water,bubbles never lie.........
  6. stinky64
    Feb 25, 2017
    59
    java center ny
    Sheep do..........
    DMiller likes this.
  7. skata
    skata Senior Member
    May 10, 2007
    872
    midwest
    I don't think those engines have a air cooler.
    DMiller likes this.
  8. mitch504
    Feb 27, 2010
    5,048
    Andrews SC
    Well, are you having a problem, or are you just concerned that you can't hear a whistle?
  9. csthompson12
    Nov 25, 2010
    90
    usa
    No, it runs good. There is a small amount of black smoke if you step on or the hydraulics load down, but that seems normal. Just couldn’t detect any sound like in other machines we have..
  10. mitch504
    Feb 27, 2010
    5,048
    Andrews SC
    Your turbo is working.
    Delmer likes this.
