Murph_MDM
As the title implies, Im looking for how many PSI the turbo should be producing on a Ford A62 wheel loader.
I installed a boost gauge and the need sits around 0 at idle and then it will max (briefly) at 7psi and typically sits around 5psi at full throttle. I am about to install a tach so I can see what rpm it is turning.
The reason for the question is that when the loader is pushing against a big pile, it can be held at full throttle, the engine revs up, the wheels will not turn the motor does not stall. Also, there is no speed differential between L and H in forward. Trying to determine if I have an engine down on power or a transmission not transmitting power to the ground.
Thinking I need to check injectors-- loader sat around a long time
Need to check lift pump also.
Trying to diagnose before I just start throwing parts at it.
Thanks,
Murph
Thanks,
Murph
