More information needed. R-134A system assumed? What did your gauges indicate prior to pulling in additional refrigerant? Are your coils, (evaporator and condenser) clean, with adequate airflow through, or across them? Is the air conditioning compressor turning when commanded to run? If the compressor is running, is the smaller, or discharge line noticeably warmer, or hotter to the touch than the larger suction line? After you've pulled in the additional refrigerant, what do your gauges now indicate after stabilization?
