Stuk_Again
Hi all,
Another new guy here with several questions...
I'm considering getting a compact ex to use "around the farm". The main job I have to do is clean up debris from two old barns that fell down. I have a FEL but am concerned about the tires getting nails and it's not very good at dealing with 12+ foot lumber. There are still two walls standing on one of the barns, about 25ft high. The barns were not empty and need to be picked through over several weeks or months which is why I don't rent a machine or hire one w/ operator. The next task will be dealing with replacing a septic system (maybe).
Also I read from one of the posters that he plows snow with his mini-ex which sunds like a good idea to me, so I'm looking at a heated cab model Like Kubota KX161 w/ thumb. I figure a smaller unit would do the job but I also want to add pallet forks and need to lift 1Ton. Question: Are the rated lift capacities "working" of will the machine lift more? According to the spec. the KX161 won't lift 2000lbs with the arm fully extended. And lastly has anyone seen a tree spade on an mini-excavator of this size. Can enough down pressure be achieved to work the tree spade?
How many hours on a used machine is approaching "all used up"
Thanks in advance
Thanks in advance
