I bought a 2004 Dressta TD8-H Extra. Tight machine and I'm very impressed with build quality. Machine of this age needs some general TLC though. Things like, the oil pressure switch leaks. To be expected after 20 years. When you price this through Dressta per the original parts book, its 208 dollars. If the switch is identical to what comes on a 4BT.390 (a super common motor), then the prices is between $30 and $60, depending on brand. Same insane price spread can be found when I price the belt tensioner on the front of the motor. Dressta OEM price is $558. When I google this for 4BT.390 motor you can find them for well under $100.
My bigger question is - does anyone know the main differences in the S4D102E-1 Komatsu motor and the generic Cummins 4BT.390. Stated differently, when Komatsu Dressta went to Cummins to produce this motor for them, what did they change from the standard design? If I know this I could save a whole lot of money. I could get genuine Cummins parts (which aren't cheap) for about 1/5 of the price of the Dressta prices.
