How do I get the studs out of the rear wheel hubs on a Deere 310L?
emmett518
USA
Found this.
Seems like a better choice than hitting them with a sledge.
Seems a little drastic, why do the studs need to be removed?
emmett518
USA
I need to install spacers to fit tire chains for winter, and I have to remove the old lugs to replace with longer ones.
I see. That hub is high strength steel, probably forged. You won't hurt the hub by pounding out the studs. Put a block behind it if you're worried about the bearing. That press, or other presses will work fine too.
