The numbering system went like this:
Prior to around May 1965, or the release of the P9, the trucks were assigned a number based upon the rear end model numbers. I have a 1964 Pacific, model SRDD-D, in that truck it has SRDD-D rear ends; I have seen Pacific model 4640 which told you that they originally had 4640's for rear ends.
Following this, the numbering system was modified to include the depth of the frame rails, the P9 had 9" deep frame rails, the P10, 10" frame rails and so on. Available were the P9, P10, P12, P12W, P12W3, P12W3 Ultra, P14 (only a handful were built), P16. I will elaborate more on the P12 models when I get home, but the W3 designation denoted a 12" deep frame rail mounted on the outside of the standard double frame. The P500 series, was essentially the replacement of the P9, and it has a lot of sub-designations as well...
Check out my website
www.pacifictruckclub.org -I will post more info there eventually
