Maybe 500 psiWhat pressure?
I would guess you need 3/4
18-22 gpmWhat is the flow rating for the motor on the bush hog? Manufacturer may be just cheaping out, or may be intentionally using smaller hoses to limit flow. I doubt if you will see much change in performance between 1/2 and 3/4 hose size.
Price isn't much different between 1/2 and 3/4. Just the 1/2" is already there on the mower, so its cost is zero.1/2” would be fine or go 5/8” but anytime you get over 1/2” price doubles.
I usually make 1/2” hoses for 20 to 25 GPM.
Yeah, been using them for a few years. Seems like shipping went up, but I may be misremembering.Discounthydraulichose.com is a good source if you know what you want.
Joe H
Better check your book. I'd guess pressure is 3000+. 20 gpm at 500 psi is less than 7 horsepower. Not even a good pushmower.
It's on a skid steer, not a skidder.Pressure isn't part of the hose size equation, but it is an important part of the cost of the hose you buy. Single braids need not apply. Double braids may be iffy depending on your skidder.
-10, but 5/8" stuff is same or more than 3/4", so no reason to not use 3/4". Maybe cause it's not as common, dunno?Without getting into all the math involved in flow/pressure, resistance, what size are the fittings on the motor of the attachment? If they're -8 (1/2"), go with 1/2" hoses and fittings. If they're -10 (5/8"), then go with 5/8" hoses/fittings. I mean, if the motor fitting threads are 1/2", sure, you could use -16 (1") hoses, but what's the point of doing that when those hoses would be sending oil through 1/2" ports?
They are either 5/8 or 3/4", I forget and I'm 800 miles away to check.If your aux. lines on the skid steer are 1/2" and the lines on the mower are 1/2" why is it even a question? You wouldn't gain anything going to 3/4" hoses if the skid steer lines are only 1/2". A high flow machine would likely have 5/8" or 3/4" lines.
