Home brew diesel injector cleaners.
Roadoil
Vegas
Anyone have a good mix for injector cleaners to add to diesel ?
My Lull with 110 hp JD 4039 has some heavy black smoke first when on the throttle then clears up I took apart the pencil injectors cleaned parts but nozzles may be partially clogged.
I have read most cleaners are parrafin aka kerosene aka jet fuel 90 percent then atf 10 percent maybe some other chemicals.
I filled fuel filter with kerosene everything I did helped a little but not enough.
If anyone knows commercial products that actually work let's hear it also but they very expensive for what they are.
1693TA
Farmington IL
FAA Radar Engineer, (Retired)
I don't work with them any longer. I have a pop tester but that's as far as I go. Local guy charges me little to test, clean, and calibrate them. If they have problems, he has parts which I do not. I think the last set of injectors I sent in were less than $125.00 to work with all four. I don't know what was done but the engine was being reinstalled after rebuild so I sent the pump and injectors in for dynamic testing together.
Roadoil
Vegas
I don't have anyone local here that reasonable from what I understand the JD pencil type are throwaway not rebuildable.
You can get pop testers on eBay $100 and actually new injectors obviously chinese a set of 4 for around $110 also but these looked OE rather just clean them if possible.
It may not even be the problem why the black smoke but what did helped some it was worse before and was going through a lot of fuel it seemed.
MarshallPowerGen
Northwestern USA
50/50 ATF and Acetone mix will clean up a lot. Are you able to pull fuel mix from a separate container and load the engine down good so it can actually clean out the gunk in the injection system? Throwing additives in and running with no load will only add to issues (along the lines of stabilizers and the like).
Roadoil
Vegas
Ok I can fill the fuel filter with that should be enough to run it hard for a few minutes.
Coaldust
North of the 60
polyetheramine (PEA) is the go-to fuel system cleaner for both gasoline and diesel. Gumout and Chevron Techron are the two major brands of PEA. It’s not snake oil. There is 40 years of data.
BASF makes most of the worlds PEA.
Coaldust
North of the 60
This Innospec OLI-9104 is good stuff, too.
I’ve been on an Innospec kick lately. This drum treated 1 million gallons. Probably overkill for your Lull. Anywho.... I like fuel and fuel additives.
Jet A contains Antioxidants (gum inhibitors) that clean, somewhat. Run a couple tanks of Jet A through it. Then, change your fuel filters. 6890DBA7-A9D7-48F7-9EAB-7A7D23E603DD.jpeg
1693TA
Farmington IL
Just did exactly this with two gallons last week in my old Mack tractor. The injection pump mounted transfer pump plunger kept sticking with this almost adhesive ooze from someplace. No notice when it was going to do it either on top of draining down the fuel filters when the engine wasn't running. I traced this back to a small piece of suction hose original to the truck, (1980) with a "Q-tiip". Ran on the inside of this hose, the swab came out with this sticky sludge. Damned bio diesel crap we are blessed with here. I replaced all the fuel lines and ran a gallon mix of 50/50 acetone and ATF drawn from a two gallon gas can cleaning all this crap right up. Discovered I had a flat tire so speed limited to 30mph, but still took a while with full throttle acceleration to burn the mixture from starting and stopping on country roads, then reconnecting the diesel tank.
Problem seems to be gone over the past several starts daily.
1693TA
Farmington IL
Thinking of this thread I started the old Mack up this afternoon as it's been about two days since last start. Before the 50/50 mix was ran through the system, about 1/2 day setting and I'd need to prime for engine start. Truck fired right off today and did not miss. I didn't move it but I'm happy the problem is seemingly gone.
