kevman6
I have a zx290lc-5 It runs great, but wouldn't come up to temp unless we blocked part of the radiator. We found no thermostats and replaced them. Now it overflows the reservoir bottle and spits out coolant overflow tube. Then eventually will overheat and shut down. It will run great with one thermostat in it with some cardboard over part of radiator, but always has too much flow into the reservoir bottle. Is there a separate bypass thermostat for the bottle? The fan sucks air through the radiator. I would assume that is the proper direction. The excavator came from a hot climate, and i am assuming thats why the thermostats were taken out. Lots of power, no other problems. Hitachi tech was just out to initialize a regeneration. It wouldn't come up to temp before the cardboard was put in. He said everything seemed OK, but needed thermostats. Any ideas would sure help.
