Hitachi ZX160 Stall fault
Jason1970
South Wales
Hi all
has anyone experienced stalling of their excavator when placing the hydraulics under load. The problem with ours is that you leave it for 30 seconds or more and it will work under load for about 30 seconds then start to stall the engine. I have placed it on maximum power setting and still as bad. The working time actually lessens the more you try to cope with it. Not brilliant with all the settings in the cab but I'm positive it has nothing to do with them, and I have tried them all
Cheers
Jason
cps
Ireland
plant mechanic
There is a little strainer filter in the banjo bolt on the fuel lift pump (inlet hose) remove that and clean it! fairly confident thats your problem!
Aiden
tool_king
new jersey
road mechanic owner
also check the water separator inlet .I have found the screen also in there along with the one on the lift pump.
