Sander85
Hi all,
I have recently purchased a EX50URG, having some issues with it at the moment.
First is that by the looks of things almost all the original wiring has been cut and botched.
I had the issue that it would turn over but not start, after some investigation I have found that the ignition switch wasn't working properly.
It is connecting to the aux circuit when you turn the key but not to the glow plug circuit when cranking the engine over.
I assumed that the glow plug circuit would go from the ignition switch straight to the glow plug bar but,
there is a thick cable from the battery + to the glow plug bar that has a interrupter switch that gets 'turned' on when you turn over the ignition switch.
Does anyone have a wiring schematic for this type digger as I will need to and want to redo the original wiring loom.
at this point only the battery light is working everything else has been cut and stripped.
the fuse box is completely disconnected, plugs and parts of the loom are missing. gauges not working etc.
Also having some issues with overheating but I am suspecting the radiator to be blocked most likely, this is the next problem to be tackled along with repairing the exhaust muffler.
Even tho there are some issues I do like this piece of equipment and hope it will serve for a while to come once I get the issues sorted.
