Adam1965
Happy New Year everyone. I have a Hitachi EX270LC with the Hino engine. To be as short as possible, the engine is overheating. If I block the two hoses going from the inner cooler to the water pump I get excellent flow through the main radiator but if I unblock them the waterflow in the main radiator stops leading to the overheating. What would cause this? I have had the radiator, oil cooler and inner cooler gone through by a respected radiator shop with no issues. The water pump and thermostat are new. The belts are in good shape with proper deflection. The o-rings and crush washers on the end of the inner cooler have been replaced. I'm desperate for help!! Thank you.
