rgl726
the problem in the pvc is not only on the transistors.
there are other ic needs to be replaced.
Hi guys,
Has anyone here managed to get hold of the shop manual for the EX120-3? I am badly in need of one as the engine on our EX120-3 stalls as soon as the hydrualics get any load. The engine just wont rev up when the hydraulics are loaded (either boom nor travel motors). Much appeciated if anyone can send me a shop manual for this machine to help me troubleshoot the problem.
Cheers
Hey Wardiker,
We changed all the filters and checked the banjo and gave it a good clean up. Still no luck.
We've got a Hitachi "specialist" coming in and said something about converting the machine to run by bypassing the sensors. See how that goes cuz the sensors on these machines I know have caused lots of people a problem
Well guys, I'm back. I finally found someone that could fix the pvc on my ex120. It's still stalling the engine and controls are fast. I went back and read all the posts. I'm going to test the angle sensor and dp sensor this weekend. My pvc is showing a code 22 and 31. Does anyone know what this means? I've also got one other problem, when you mash the (P) or Power button the engine revs up and dies. This has been going on since I've owned it, even before the hydraulic problem. Does anyone know what would cause this, maybe the ec motor.
With the key on and engine not running you should have 24volts to one wire on each of the displacement solenoids, (the ground is controled by the computer and you can not check this easily.) If you don't have 24 volts to each solenoid then you can check the fuses first there is a one amp fuse for each in the fuse box. Make sure they are good then go from there and check the wiring from the fuse box back to the solenoids. Hope this helps.:canada
Hey 3Doc, I have been tryin to log into this forum for very long time now, my password wont reset must be some admin issues, so i created a new account. My previous username was andre01.
Thanks for the suggestions, I got 21.7 volts across each solenoid, i guess thats bcaz the battery was low, with the engine running i get 26volts.
Since my last post i did a lot of things.
1- I replaced the displacement solenoids with new ones.
2- Resealed the swing motor
3- replaced two solenoids on the pilot solenoid valve ( boom and swing function)
4- replaced the DP sensor on the control valve
5- Replaced the PVC
So here is where I am after that. The machine was overheating , was super fast, would easily stall at full extension of any cylinder or under load, and the hammer would stop firing if i move any other function while hammering b4 i replaced the DP sensor,
Now it is not overheating , functions can be operated simultaneously therefore no problem when hammering and will not stall provided that I select tortoise mode and a power greater than Idle.
If I am not wrong, of the two solenoids on the pump, one is for increasing flow and the other for decreasing. I have noticed however that the machine will not overheat and such if the wires are switched around.
When i connect the wires as they should It overheats, but the machine is very strong and as fast as it should be and will not stall provided i select tortoise mode and a power mode greater than idle (eg. L).
Mayb i am wrong plz inform me of which wire ( color code) goes to the solenoid nearest to the door/ front.
My next big prob is that the swing is very weak, all other function are strong except swing, The machine fails trying to sweep an object to the side. Also when on a hill I hav noticed that when swinging the machine it will not come to rest quickly when the lever are in neutral, it swings a good bit b4 comin to a stop.
Angle senor voltage is 4.4volts, i blew air through fuel line back to tank and drain tank which gave improvements in speed. what range voltage should i get on the rpm senosr?
My temp gauge doesnt work.
Any Ideas? Thanks.
here is the first thing to do with the ovrheating problem.
remove the engine thermostat and observe the machine.
this is located on the engine water return line to the radiator.
pdsv 1 is one near the door. pdsv 2 is near the engine.
I have sent you an email with the page from the manual to set the voltage. Let me know how it works.
