63 caveman
I did a swing gear seal on a JD 120 a few months back. I think the seal got damaged by to much grease in slew bearing pushing parts of the seal into grease bath that got picked up and jammed into swing pinion shaft seal. Got the replacement seal from JD dealer and it was an upgraded part (much more robust than the original) and was a bit pricey, over $200 if I remember right.
Good luck
Good luck
