knightgang
Well, I had been looking at a EX200, and then a EX120 posted on Craig's list only 1.5 hrs from me. I took a look at the machine and it is pretty tight. Biggest complaint I have is that the bucket is pretty sloppy on the front pin. Seems it is kinda pricey to line bore a bucket to make it right and tight again.
The hour meter stopped at about 4800 hrs, but with the condition it does not appear to have more than 6-7K hours on it.
Issues we found:
Hour Meter not working
Coolant Temp gauge not working (needs temp sender)
Both boom cylinders with minor leaks, probably top seals dry as the machine has been sitting for a little while. (No immediate worry)
All Electronic controls work except Engine shutdown with the key. (Should be a simple fix)
Couple of hoses behind the boom look as though they are in need of being replaced, look to be original
Is there anything else specific to a 120 that I need to be watching out for. UC is in good shape, tracks are mostly good, 2 are broken. It could have seen a grease gun a bit more often, but everything is still tight, so it has not been too bad.
I called the dealer on the Temp sensor and hour meter, and they want like $400 for an hour meter. Where are some other sources for these parts mentioned above? Also, if I get the machine, I would like to look for a used bucket that is in better shape that I can pick up for less than the cost of line boring.
Thanks
Issues we found:
Thanks
