Welcome DF
Was any work on the valve bank prior to this? I had my 120-3 valve bank resealed and had a similar problem (mine was boom up was really slow everything else was fine). Long story short, when it was put back together one piece (some sort of a spacer or cap?) was put in upside down. We tried a conversion kit and it had the exact same symptoms, so went back to electronic. It took awhile to figure out because of the electronics (I ended up with all new sensors).Once we put the piece in properly it worked as it should.
If that s not the case in your situation I would recommend mg's idea of reading the codes over a conversion kit. Also you may want to check your wiring plugs and harnesses, they should be secured so they dont vibrate too much during operation, there are (or should be) clips and tabs on the hyd. pump and valve bank to attach the wiring plugs. If not zap straps or something similar should work.
