Need to buy a wiring harness, but need to figure out for sure which machine I have. The plate riveted low on the side of the cab is gone.
An operators manual for a -3 machine came with it, machine looks like the one pictured in the manual, always assumed it was a -3, but when I had to buy a pump drive coupler it used the (much more expensive) -2 version.
Interior controls are identical to the ones pictured in the book. On the exterior of the machine it has the blue and purple offset vertical stripe. Says "EX120" and "Super" on the side. On the door it says "ELLE" and "electronic load sensing excavation system."
It seems that the two machines both fit that description.
Any way to tell the two apart with the tag missing? Because of the drive coupler I'm thinking it's the -2, but I can worry that it's an early -3 with some -2 carryover.
The flip side of the question, what would be the difference in the wiring harness between the two?
Thanks.
Thanks.
