Hitachi EX 1 20–3 no power to control panel #2
Slam 99
I have a Hitachi ex 1 20–3 I’m not getting power to control panel 2 the one that his track speed it will only track in turtle mood
I have checked all the fuses they are good
I have a manual throttle cable on it
Any help would be appreciated
mg2361
Pennsylvania
Equipment Mechanic
Welcome to HEF Slam;)!
Your fuses may be good, but is the voltage getting to switch panel 2? Does the panel have a good ground?.
Slam 99
No I have no lights on control panel #2 none of the buttons respond and it is stuck in turtle mode track only everything else is fine
I found a thread on here telling you how to read the codes on the computer my codes are 18-23-32
mg2361
Pennsylvania
Equipment Mechanic
18 - Failure of the PVC
23 - Not listed, did you read this one correctly?
32 - Short circuit of the Temperature Sensor
These codes will not affect your #2 panel. If you have voltage to pin's 1 and 2, good ground at pin 19, then I would suspect a bad switch #2 Switch Panel.
Slam 99
Thanks yeah I’ll double check the codes and 23 was one of them when checking those pins is that at the harness going to control panel #2
mg2361
Pennsylvania
Equipment Mechanic
Yes. When checking the voltages, do it by backprobing (carefully) the wires at the connector. Checking the open source voltages (connector disconnected) only shows voltage potential.
mutti_wilson
Washington
I had a similar issue on my machine. One corroded wire in a connector in the armrest was all it turned out to be.
