Hitachi 120-5
Darragh120-5
Ireland
Hi all, I have a hitachi EX120-5 not sure what the problem is every now and again it starts to get very jittery sounds as if it is low on oil or air in the system if you swap the digging setting to a different one on the dash panel or even stop for a minute it comes back to itself digger has just over 6000 hrs genuine just wondering is it a big fix or has anyone seen it before thanks
uffex
Lincoln UK
Admin
Good day and welcome
Suggest you check out the tank air pressure, see attached.
Kind regards
Uffex
  • GI Tank positive air pressure.pdf
Darragh120-5
Ireland
Thanks lads I see some of the studs is rung off the top valve but it is still holding pressure when you push the top of this valve you can release the pressure so it is holding I will have get new filters for it and get back to you but by the sounds of your replies it must not be anything to get worried about I’m new to the digger scene and was looking to buy a mulcher for the 120 but I just want to make sure the digger is fit for purpose first thanks again
Steve Austin
Tullahoma TN
When you say jittery do you mean pilot controls are vibrating or do you hear a surging or vibrating sound in machine.I know you stated when you change modes it goes away for a while.
If you shut engine off and start back up does it go away for a while then come back? Does it get worse or more frequent as machine heats up?
uffex
Lincoln UK
Admin
Good day
Check the hydraulic fluid is not foaming, the strainer filter for the pumps is clean.
Kind regards
Uffex
Diesel Dave
Ontario Canada
sorry I was mistaken with original part #.
EX120-5 hydraulic tank cap filter part # by serial number.
Part # 4371823 , SERIAL NO. -056232
Part # 4437838 SERIAL NO. 056233-
Darragh120-5
Ireland
There is a surging sound as if the machine is starving itself of oil now I have spoken to a guy today and he has told me that I have the wrong hydraulic fluid in it I have hydraulic 32 oil in the machine and he has told me it needs 46. It does get more frequent as the machine heats up as it doesn’t really start until machine is running for a few hours
Steve Austin
Tullahoma TN
Just read your reply and noticed what you stated about the hydraulic oil. Your EX 120-5 had Hitachi 46N full synthetic what they marketed as their 4000 hour oil.
Can you tell me how much of the 32 hydraulic oil you have added to the system?
Is the oil in your hydraulic oil level sight glass crystal clear or does it have a brownish look. (this will be an important clue to what My response will be.)
I will not have time to reply until tonight but I will explain in detail on subject tonight.
Darragh120-5
Ireland
I have more than likely added around 20-25 gallons of 32 due to busting hydraulic hoses in the past 2 years as I am unsure of what age the machine acctually is I was told at the time by someone that hyd 32 was the correct oil but this obviously isn’t the case it’s no problem I can drain all of it but it has done a fair bit of work with it in it I will get a picture of the oil sight glass to show you the colour of it in the next hour or two thanks again for the help much appreciated
Steve Austin
Tullahoma TN
Got time for a quick reply, have you noticed any of the hydraulic functions acting odd especially boom down has it on cool morning not wanted to boom down than when warms up operates ok.
Do you have any guess on how many hours on unit with 32 oil in it.
Please send picture of monitor if it is the monitor I am thanking about we can look at some live data also.
Darragh120-5
Ireland
It has more than likely ran for 150 hrs on the 32 oil maybe a bit less if I can get a video maybe of the problem occurring but it will more than likely be a week or two
Darragh120-5
Ireland
I haven’t noticed any problems with the booming down when cold or warm but I think my best bet is to drain the hydraulic oil and replace with 46 and change all filters again and then go from there I have also been told it could be a faulty solenoid somewere but the advice I’ve got locally doesn’t seem to be great advice
Steve Austin
Tullahoma TN
I will post info on the oil situation later, but have you checked the oil level in hydraulic pumps splitter drive housing? The dipstick to left of housing looking at rear of pumps.
