CraneInnovation
Hey guys, I'm wondering if you could answer a question my friend and I have about hill climbing with an excavator. Neither of us are professional operators, but we can handle a hoe pretty well for novices.
When climbing a hill, it seems like the convention we've heard from most operators is to reach up the hill and pull yourself up. We did a job recently with some steep hill climbing (in 4-5 ton minis) and we found that rarely worked. However, turning around and pushing down with the boom and stick worked every time. If the machine had juuuust enough traction, reaching up the hill with the stick all the way out seemed to give the tracks a bit more bite. However, as soon as traction failed, putting the bucket into the ground and pulling didn't help much. However, swing around and push.....and up she'd come.
I see pictures and YouTube videos all the time with a hoe stuck down a hill or in a hole with the boom reaching up the slope to no avail. If this technique seems less effective, why does it seem to be considered the "right" way to do it?
I tried to think of a few reasons on my own, and the only ones I came up with were that you can better see where you are going and you technically have a bit more hydraulic power available because you're pushing with the stick cylinder instead of pulling. However, most machines can easily push their own weight up anyhow.
Is there another mechanical or safety reason why pulling is better than pushing?
Thanks!
Thanks!
