High Flow machine and Standard flow attachment question
aussie-farmer
australia
Hi there,
Added to our shed ( but yet to arrive) a New Holland C332 (high flow 131L/min) Track loader, we have a Norm 6ft slasher that is standard flow. Is there a hih/standard flow control on this machine or will it be simply a lower engine speed task ?
Maybe a flow restrictor of sorts is avail if required ?
I just coulnt find info on in cab settings or switch etc to reduce flow rate - know John Deere have a switch from Standard to High flow in their machine.
Any info around this would be much appreciated.
Thank you.
Tones
Ubique
Standard flow is what the 4 in 1 bucket uses so without touching anything it should be good to go.
KSSS
excavation
Yes there is a switch on the left side. it will say HP/HF. It detents both ways. Your machine has High Flow, but not the Enhanced high flow system which is what the High Pressure switch is for. So when you want regular flow, just leave it in the middle. When you want High Flow, depress that side of the switch.
