kyle sutton
Looking for some help with our 299D skid steer. The quick coupler to change bucket to forks isnt working from the switch inside the cab. I can use my power probe and apply a ground and 12 volts directly at the back of the coupler motor and it will work fine. I only have 3.6 volts and the back of the switch coming from the ECM. I have replaced 3 relays in the engine compartment on the unit still voltage is 3.6 the last 8 of the Pin are JST01217 thank you for any help
