Therapydoc
Bought a used backhoe, everything works as it should. How can I figure out what hydraulic oil is in the system? Books calls for ISO32 or 46. The old man says he used whatever you’d use in any regular Deere. Typical old man set in his old ways. I want to make sure im using the right oil. Granted he had the machine for 15+ years but couldn’t say exactly what type fluid it was. Will an oil analysis tell me this? Sorry but for $1000 worth of oil, I’m not changing it all. Don’t use the machine enough to justify it. I just need to be able to add but have been told mixing oils can be a bad idea also.
