stumpjumper83
Use an excavator.... really? I think good dozer hands must be hard to find in your neck of the woods. A 30 - 40k pound dozer equipped with a proper road building angle blade and a good operator can really sling some dirt. There is no backing up, you moving material all the time. When you get to the end of the road, turn around, **** the blade the other way, and head back, again, working all the while. I'll bet in easy digging your tossing a cu yard a second over the edge.
Excavators do have there place though, when you get the trail in and want to make a truck road out of it. After you can no longer single pass the dirt over the edge with the dozer, then the excavator shines as the dirt only needs to be handled once. But then you still need to dress up with the dozer after the hoe has done its thing.
