Good man. That means the Turbo Gp is an 8N-0582 and reduces the engine arrangement options from 4 to 2. Both are 75V-prefix: -
8N-0529 which was built from 75V4283-75V5249.
8N-2543 which was built from 75V5250-75V7344.
OK, what identifies it is the expansion tank for the cooling system - see diagram below. One engine arrangement has it, the other engine does not. Your engine does, it's clearly visible on at least 3 of your photos.
Therefore it is my considered opinion that your engine is Arrangement Number 8N-2543 and has a Serial Number somewhere between 75V05250 and 75V07344. That should be sufficient to get parts and service information for it which I assume is your aim.
