Mini305CRNewbie
- Joined
- Oct 16, 2019
- Messages
- 2
- Location
- Leavenworth, WA
- Occupation
- Office Manager, Apprentice Operator
I have a CAT 305CR - mini. My boyfriend has been operating for years and seems to think I should be able to do what he wants with no direction whatsoever! I know what I want to do with the mini and I know what it can do, though I really can't seem to combine the two.
We have/had a ditch (for a drain field) that runs around the back of the house/shop and off into the woods on our property. The BF of course straddled the ditch and dug the entire thing. I walked the entire thing as the "ditch witch" holding the transit and telling him to dig or fill as we went. After completing the drain field he covered a few sections of pipe with 6 to 8 inches of dirt, I think just to hold the pipe down. Then tells me to backfill the ditch!!! I have used the mini occasionally to pick up logs and randomly to move things. I learned how to dig or scoop a bucket full of dirt with a CAT 320!!! just 2 days before he told me to backfill. BIG DIFFERENCE in the digging scooping and lifting power.
So at this point I have managed to push (with the blade...which I love to use and he hates) pull and drag 99% of the dirt he had piled up on the sides of the ditch back into the ditch. - I should mention he wanted me to backfill by straddling the ditch like he did while digging! That scares the crap out of me! I don't want to fall in, don't want to tip over and really don't want to break the machine! (I still squeal and panic if I lift a track off the ground pushing to hard).
Anyway, as I said its been refilled...but it looks like a million Tonka truck bumps and hills. I keep trying to slowly rotate the house with the bucket flat on the ground to smooth/level out the mess I've made like he's done a hundred times in front of me. But its making things worse. He says I cant drive down the ditch to pack it with the tracks or scrape it with the blade....so I'm seeking any advice you experienced operators can offer.
I have OCD and it is killing me and my pride that I can't just make the damn ground flat. I'm very easily trainable, if he had just stood outside and told me what he wanted and which stick to do it with I would have learned the technique I should be using. Instead, I know I have learned bad habits and the wrong way to do things. Any advice will be greatly respected and appreciated.
Thank You
Thank You
