Hi Everyone,
I am new to the forum and have a real head scratcher. Equipment is a 2006 Bandit 250 XP with the John Deere 4045. It has an electronic DE10 injection pump.
Ultimate Problem = NO START >>>>>>>>>>>>> HOWEVER - when I use Ether in the air intake it starts and runs PERFECTLY ------ And stays running perfectly even when Ether is stopped. As soon as I shut it down it needs the spray to get it going again (hot or cold does not matter).
I have checked the as much of the wiring as possible (i have a schematic) however this is a brush chipper so the wiring is not the best for sure. I have had the DE Injection pump rebuilt as it was leaking from the weep hole on the bottom and I thought that the control solenoid may have been the issue.
I have checked the output of the crank sensor and it is at 140 - 160Hz when the ECM is unplugged and the engine is cranking.
I am now thinking ECM (RE532628 L12 / 12v EXT) however this is a Major purchase especially right after a new injection pump was installed.
What ECM inputs are required to begin the injection during cranking? Am I missing something obvious..... ?
ANY HELP WOULD BE GREATLY APPRECIATED.
YourPalAL
YourPalAL
