Tuckerdog
I have a 939C Hystat that is a great little machine with 2800 hours. I was running it today, shut it down to run the excavator, jumped back on the loader, and there is no power to the dash at all. I checked all of the fuses below the dash, checked batteries, made sure there was power to the starter, and still have zero power to the gauge panel or ignition switch.
I removed the ignition switch, and did not take a picture or mental not where the three wires go. I have a yellow, green, and red wire....needing to go to battery, start, and relay on the ignition switch. I wanted to get it wired since that obviously isn't my issue.
Are there any other areas to look? Other fuses, relays, etc...? I'm at a total loss and really need to use the machine. Appreciate any and all help.
