Baltoi Ionut
Hello, I would like you to help me with the following problem with the th330b crawler.
I have a problem with the gearbox, all gears work except one.
Namely speed 1
I also changed the 1st gear solenoid, without result
When I try to start gear 1, the car behaves like this:
I put the lever in 1st gear and put it forward.
It shows nothing on the screen, it shows all N
But during this time the car wants to go forward a little and then stops, like when you want to start gear 1, but you can't.
The same thing happens when I shift into reverse
He wants to go out for a bit and stops
The rest of the gears work perfectly
What would be the cause?
Is pressure leaking somewhere? Do those box pistons have worn rings?
Have you come across this before?
Wait for a response. Thank you in advance.
Namely speed 1
