I'm thinking emergency shut down like khansen mentioned, or blower seals etc.
My 6-71 inline with no turbo doesn't black smoke at all, and I'm working the snot out of it dragging around 80,000 of crane.
Mine will tend to burn off slobbered oil that wet stacks in the exhaust manifold when I'm doing too much idling on a jobsite with the crane. Usually about 3 miles down the road it gets the exhaust manifold warm enough to burn it out. It doesn't use much oil, but it will smoke that out when it finally gets hot enough.
If he's sitting there quite a bit between turns, and then has a hard pull, it may warm it up enough to burn that oil out.
If yours is wet stacking you'll see it around the exhaust manifolds and piping.
