trakloader
#2060 HD in poor shape. Old M&B workhorse #H208 has been saved. Nice truck with a special preload 5th wheel
Poor old HD, it looks like she'd fall apart if you sneezed.
Thasnks HDX,couldnt get the rusyt door open,thanks for the history.Its always neat that every piece out there has touched someones life and has stories to go with it if you can find the right person that knows.We dont just find iron,we find history and stories as well,and fill in missing pieces of other peoples gear and history.Good work all!!She is an ex Rayonier Truck Trakloader They had CPS in the diamond on the doors but I think about this time CPS became Rayonier or the other way around These trucks were delivered under Master Mechanic Hal Fladager There was 6 HDs all spec'd the same NTC335 Cummins engines and 1263A main trans with 8341 aux trans also had SRD rear diffs with 7.54 ratio so they had a top speed of 51 MPH Dont know what the story was on the first truck(Delivered Jan19 1970) but the others came in 2132 2133 Feb 4 1970 2134 2135 Feb 10 1970 and 2136 came Feb 12 1970 They also got 6 P9 Pacifics about the same time. Over time however as with everything else these trucks were reduced to bullcooking One became a line horse and several became fire tankers These were VERY CLASSY trucks in the day Sure would like to get the remains of that truck (and the factory sign) sure is a lot of potential there. OH by the way her serial # is 0033927
Gord Barney - never heard of him before and so thanks for the info. How are these books?
Skadill just for your info Those J/R trucks did not come with tachs or speedometers in the dash like all the others They had two Sangamo "Tattletailers" mounted on top of the dash with the removable day cards Both of them still work in unit #2133 George Fredricson from MtSicker Logging in Duncan has one of the P9s. Out of all these trucks there is very few survivors I saw one of the P9s at the scrapyard in Cassidy some time back but she had a ton of waste steel jammed into her cab so even that was unsavable--- Win Some Lose Some
taken last spring
Trakloader, HDX; Funny - Here are pictures of a 1963 HDX with square door windows and no vent. I am pretty sure it is the original cab. So I guess it must be one of the last Hayes that had the old cab![]()
HDX; Thanks for some very interesting information/history. As you have told me, every Hayes built has it's own personalityHayesno1 If you ordered a Hayes and you wanted the old 24x24 windows then you got 24x24 windows It was just that you had to specify that you wanted them because the door was different. The problem with most of these trucks today is you just dont know how many times the doors have been changed or what the story is on them.A good example is to see how many Hayes's have the "New style" doors the ones with the extended lip for the drivers arm( in fact it was designed as a stiffener) because the old style doors had a tendancy to crack right accross where the vent window was situated. While we are on the subject of vent windows on the Hayes HD WHD HDX the problem everybody has today is to find the vent window rubber. These were made by ACE Rubber in Vancouver They sold out to Accurate Rubber after Hayes went down and there was no call for them so they threw out all the moulds due to being obsolete. BUT if you ever find an old Pacific door and the vent window rubber is good WELL grab it because the vent windows are the SAME More trade secrets here going out the "Window" Sorry I know its a long winded answer but now its out there
