Hi there,
The laser will only done one grade so the easiest way is to place the laser over the curb line, this stops any messing with levels and keeps it simple. Then turn on laser, it will auto level, set receiver next to laser and kerb line. Then get your man to stand at your bottom kerb line and pick up the laser beam.
Now while you alter the beam up or down using the arrows, get your man to move the receiver up or down accordingly and talk to each other letting each other know what is going.
Couple of things. Make sure laser front face is square with the gradient, check the cross on top of laser. I cannot remember if laser beam moves front to back or left and right, but it only means moving it 90deg around. Also when you turned off the laser it resets back to level so you have to restart again.
Good luck
