Hmmmm. I'll need to research that a bit. Probably well known by the folks that work with microwave towers and gear, but I never have.
Tell you what will give you a hell of a snap. When working with helicopters slinging up loads off a barge on open water to be hauled by air, there is a short nylon static strap that is to be rigged off the hook. Twin rotor machines are the worst. Anyway, the chopper builds up a big electrical static charge, and if you touch the hook or any part of the machine when it is hovering, you will get a pretty good jolt. Very unpleasant.
What you want to do is take the static sling the crew chief throws down to you, rig the lifting lines to that, then snap it onto the chopper hook, being very careful not to touch the hook. Even with that, I've seen and felt an electrical charge jump the static strap and use me for a ground sometimes. It's high voltage but small amperage and very unpleasant.
