Goodall Jump packs
Mr. Wrench
Ohio
Mechanic
Do you have any pictures of your jump cart? I completely understand what you are using it for. I've been to a local auto auction and they have a golf cart sized vehicle with a jump pack system built in to the back of it. They drive right down the row of cars, jumping any of them that won't crank on their own. I'm not sure how they charge their batteries, maybe off the golf cart engine? I didn't look that closely
I will try to post some pictures of it. I have never posted pictures some I'll have to figure that out. Just hang on it may be alittle till I can.
I have two sets of booster cables on it, 2ga. each. The clamps I think are the bottle neck of it, that is why two sets. You can only get so many amps through the clamps. If you are starting a truck with bad batteries you put both sets on to get the amp flow you need. If it is real bad sometimes I hook one set to the starter and one set to the batteries. For 24V I can unhook a ground cable to isolate one battery and use both cables. When you do that the alternator only changes on one cable though. Usually what we do for 24V is, we have another jump starter that is similar ( version 1 ) that we use. One jump starter hooked to each battery and make sure the vehicles are not touching. The machine doesn't have a choice but to start. One of the keys to why it works so well is the engine driven alternator. Yes it keeps the batteries charged, but it allows you to rise the voltage about 2V and push more amps into the machine you are starting. If you are just starting cars and lawnmowers you don't need to have the engine running.
Mr. Wrench
Ohio
Mechanic
I have thought about making another one that is smaller/lighter. I tend to overbuild things and it is heavy. I would probably use lighter steel in some areas, maybe smaller wheels, stay with same size engine and alternator, but maybe one less battery. Some people say," you should put a semi alternator on it". Why, I've never ran the batteries anywhere close to died and then I would have to use a bigger engine. I may unhook one battery for a while and see how it does. It is heavy enough that I can't load it up ramps without help and it would be nice if it was lighter for when I take it away from the shop. What do you guys think?
One thing that would be nice to add to it would be some of the products from Polar Wire. I saw a link on here somewhere for one of you guys in the northwest. Looks like they have some good products, bigger cable, better clamps ect. Not sure what shipping would be though.
Wow, didn't realize it would cost that much to build. It would be a lifesaver though when you really needed it.
Sometimes you need to get multiple machines going in freezing temps so need something extra heavy duty.
Mr. Wrench
Ohio
Mechanic
Good grief, guys. This thread was about jump packs, not something to start a locomotive.
Ya, sorry I derailed it. The small jump pack I use is a MAC. I think the same as a JNC. It works ok if I keep it charged up. Thought about getting a NOCO one and trying that. It may have more power than the MAC but not a pricey as the Goodall.
Shimmy1
North Dakota
No worries. Just hoping when my Goodall wears out, I don't have to expect a couple of junk ones before getting a good one.
Mobiltech
Sask.
I have a noco and it’s a pita.
It won’t boost anything if the battery is completely dead.
I set up a Milwaukee 18v with a jumper adapter and it will start anything smaller and is good for running a 12 volt winch without a battery connected.
I have an old atv that sits unused a lot. I rigged up an adapter to run it off an 18v Milwaukee. Every time I used it I just lift the seat and pop in a battery and it’s good to go.
I figured it out one day that I have 38 12 volt batteries in all the stuff I run so it’s hard to keep up with them all.
On my lithium jump starter you have to push a button on the cable connector for about 3 seconds in order to boost a dead battery. If the battery isn't dead you push the on button.
