Frankhaddad
Detroit series 50 engine, Allison transmission. This unit has been modified into a motor home. Retarder does not work, wired to schematics that I could find with a module and joystick type controller as well as on/off switch. Have not been able to get it to activate during road tests. Have two codes Engine speed sensor, (22-14) and oil level (14-12). Not sure if these will have an effect on it activating or not. Also the cooling fan is supposed to be PWM variable speed but runs wide open. I have run the wire from engine ECU to fan solenoid, customer mentioned he had a Sauer-Danfoss unit but I can't find it in any drawings. The running gear (engine, tranny, etc) are all from a gillig bus mid 80's. Any info would be a great help!
